HVAC and 4x4 problem
Old 10-23-2010 | 03:58 PM
blazer1206's Avatar
blazer1206 is on a distinguished road
Default HVAC and 4x4 problem
I have a 2001 blazer LT with the 4 button 4wd the problem I am having is my lights just flash when i go into 4wd i checked the accuator under the battery and I have no vacuum there or on any other lines I have been going through this forum and couldnt find and answer and also my HVAC is stuck in vent mode which I am assuming is also due to the vacuum problem i am having could anyone tell me how the vacuum lines should be ran I have tracked them all and wind up at the fender but have no clue where it goes from there
Old 10-23-2010 | 04:35 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
the one in the left fender is a reserve i believe. most likely you have a vac line up under the dash unhooked
Old 10-25-2010 | 04:08 PM
blazer1206's Avatar
Where does the vacuum to the reserve come from I see a line going into it but where does it go from there I can trace all the lines but i dont see any going to the engine
Old 10-28-2010 | 09:17 PM
ArRay68's Avatar
ArRay68 is on a distinguished road
supply is on driver side upper intake.When you take off air intake you can see it.
VKING
06-12-2012 10:21 PM
c3mp69
05-13-2011 02:30 AM
rsheltro
12-26-2008 10:11 PM
mohawks76
11-25-2008 03:24 PM
sdm1234
02-07-2008 07:16 AM
