HVAC - Vent Problem
Old Oct 3, 2012 | 10:21 AM
zdorsch's Avatar
zdorsch is on a distinguished road
Default HVAC - Vent Problem
Hello All,
I have been reading through old posts, but have not come to any definite conclusions yet. I have the "computer climate control" on my 2000 blazer LT. My heat and ac work and I can change the temperature, but I cannot get the vents to change--currently air only comes out of the dash vents. When I turn the switch for the vents I can hear something moving behind the HVAC control, but the air keeps coming out of the dash.
I have checked the fuses and the vacuum lines. Does this sound like it may be the control unit itself?
Thanks,
Zach
Old Oct 3, 2012 | 12:08 PM
Rottidog's Avatar
Have you checked ALL the vacuum lines including the vacuum accumulator under the hood or in the DS fenderwell? The lines leading to & from it & under the dash?
Could also be the blend door that's broken or disconnected.
Old Oct 3, 2012 | 05:56 PM
LannyL81's Avatar
Yep...as stated above....likely the vacuum swith on the control panel. Take the panel out and check the vacuum connection it is probably leaking.
All the vents are controlled by vacuum motors or actuators. If the vacuum is not getting to it, it will not move.
Just be careful with those colored vacuum lines....you do not want to break any of them.
I think the switch is not too expensive to replace.
Badco
Aug 24, 2013 06:20 PM
BlazidicReaction
May 30, 2011 01:19 PM
blazer1206
Oct 28, 2010 08:17 PM
starcruiser
Oct 17, 2009 10:52 AM
mohawks76
Nov 25, 2008 02:24 PM
