hydrocarbon problem
Old Jul 12, 2010 | 04:24 PM
coyote0630's Avatar
coyote0630 is an unknown quantity at this point
Unhappy hydrocarbon problem
ok i need some help out there... i am trying to get my 95 blazer 4x4 4.3L to pass nj state inspections and keep running into the same problem.. the only reason it fails is due to Hydrocarbons being too high in low speed idol.. the numbers are more then double what is called for (putting out 507 ppm when should be 220 ppm max) i have replaced......
CAT, O2 SENSORS (BOTH), TPS, EGR, MUFFLER (LESS THEN 8 MONTHS OLD).....
Im at my wits end trying to figure this one out...
any input would be appreciated
Old Jul 12, 2010 | 09:07 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
I'd suggest you check out the sticky thread 96+ fuel system diagnosis. Could be your fuel pressure is too high due to a bad pressure regulator or you have a leaky injector which is causing a fuel excess at idle.
Old Jul 13, 2010 | 01:52 PM
coyote0630's Avatar
the "spider" assembly is new out of the box 8 months ago.
hotrodsbyg
Aug 15, 2011 11:47 AM
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
