I cant get my 4wd to work
Old Jan 20, 2020 | 02:39 PM
Sawman's Avatar
Sawman is on a distinguished road
I don't have a vacuum gauge
The cable pulls about an inch maybe an inch and a half?
Old Jan 20, 2020 | 04:04 PM
LesMyer's Avatar
Not the same problem that you have but description of operation is good. Yours is the NV233 in the article.
https://blazerforum.com/forum/tech-a...4hi-4lo-41226/
This article says 1/2" TO 3/4" of cable travel. If you can pull your cable 1" without locking that right front wheel, then the problem is internal in the axle mechanism. See photos and diagrams in the article.
Old Jan 20, 2020 | 04:43 PM
okaussie's Avatar
okaussie is on a distinguished road
If it really is moving 1 1/2 inch could be the cable is broken and not pulling on the shift fork.
How easy is it to pull on the cable?
If it is working, could be partially engaging, could be the return spring on the shift collar.
Does the cable return to its normal position after pulling on it with no vacuum applied??
Bill
Old Jan 20, 2020 | 05:10 PM
Sawman's Avatar
it's pretty hard to pull
I have a new cable I can install if you think that will help
how hard is it to get to the inner working components if I have to
Old Jan 20, 2020 | 05:28 PM
okaussie's Avatar
It could be that your cable is seized up due to being dry on the inside coupled with age and environment. How old is it?
It is pretty simple to disconnect it from the front axle to test the cable by itself.
3 Bolts then remove the plastic housing it is connected to. Then look inside and you will see the cable attached via a spring to the shift fork. Just pry the spring up a little and the cable will come undone.
Then recheck your tension on that cable. If it is still hard to pull, replace it. If not, then we have to look deeper.
Old Jan 20, 2020 | 05:55 PM
Sawman's Avatar
Sounds good
I have to work from dawn till dark the next week but I'll look into it and let you know soon
Thanks a lot for the help
Old Jan 23, 2020 | 01:31 PM
Sawman's Avatar
I just replaced the cable
It was sticking up by the actuator
I can plow again!
Thank You so much!
Old Jan 23, 2020 | 05:00 PM
LesMyer's Avatar
Glad to hear repairs were a success!
Old Jan 23, 2020 | 05:40 PM
okaussie's Avatar
You did put gasket sealer between the plastic housing and pumpkin, right?
If not, you run the risk of water getting into it or leaking diff fluid from it if the rubber seal blows on the shift fork..
Bill
Old Jan 24, 2020 | 04:44 AM
Sawman's Avatar
Bill
No I didn't think of that
I am off work today so it will be the first thing I do!
Thank You!
