I need help!!
Old Feb 10, 2010 | 07:36 PM
youngone's Avatar
youngone is an unknown quantity at this point
Default I need help!!
I hate to be demanding but I'm in serious need of help.
I was driving my 01 Blazer LTZ in 4 hi through the snow when I hear this grinding type sound and then the front wheels locked up.
I pulled off to the side of the road and checked the front wheels.
Theres some type of wire on the drivers side that goes to the caliper(?) thats broken...what is that wire? Theres one on the passenger side as well.
Old Feb 10, 2010 | 07:38 PM
Wheel speed sensor wire maybe?
Old Feb 10, 2010 | 07:39 PM
youngone's Avatar
Im not sure, I was thinkin ABS(?)
Something causing it to lock up in 4hi and I was hopin it was that wire....but not likely.
Old Feb 10, 2010 | 07:40 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
that would go to the hub, unless the op is thinking brake line as a wire
a speed sensor wouldn't cause lock up, i'd sooner think a caliper that isn't releasing well, can you jack it up and turn the tires freely
Last edited by swartlkk; Feb 10, 2010 at 07:44 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT function to add additional information to your post if another member has yet to reply.
Old Feb 10, 2010 | 07:42 PM
youngone's Avatar
Im sorry, I forgot to add it runs next to the brake line but goes up into the engine bay.
All i Know is its an actual wire and not a hose.
Old Feb 10, 2010 | 07:43 PM
Its the wheel speed sensor wire. Your ABS probably locked up due to the lack of signal from that sensor.
Old Feb 10, 2010 | 07:44 PM
Banned
if you pull the plastic flap on the inside of the fender is there a connector it goes to. i think its a black connector.
Old Feb 10, 2010 | 07:51 PM
Good guess! Only 95% of the connectors on the vehicle are black! LOL
There will be two wires, most likely white and gray on the sensor end. It will connect to a connector with a light blue wire and a yellow wire. Splice them back together with some 3M heat shrink type butt connectors and maybe some additional wiring and see if it fixes the problem.
Old Feb 10, 2010 | 07:55 PM
Banned
i dont know if that will work. those sensor rely on resistance and even the smallest difference will effect them. same thing happened when my balljoints broke and tore the wire into. we spliced it back together but no dice. its worth a try but even a crimp splice could throw of the resistance reading. i don't even know if you soddered it then used heat shrink if it would worth. i guess its worth a shot before you dough out the 100 and some bucks for a new bearing+sensor
Old Feb 10, 2010 | 07:56 PM
youngone's Avatar
I hope thats whats causing it.
The wires broke at the wheel. They ziptied it tightley to the control arm and look as if it did have enough movement range. If that makes sense LOL.
I dont have the car at my house as I was alittle nervous driving it, but I'll give it a try tomorrow. Thanks guy, much appreciated.
