I Think I have a serious Problem
Old Feb 1, 2014 | 07:36 PM
GaBear's Avatar
GaBear is on a distinguished road
Default I Think I have a serious Problem
Ok I go to do my first oil change on the Blazer since I bought it 4 months ago. when I pull the drain plug I notice some small metal flakes. after I drain the oil the pan has some silver flakes in the bottom of it. When I take the filter off the same thing. Should I be concerned or is this something that I need to just monitor???
Old Feb 1, 2014 | 08:14 PM
richphotos's Avatar
is the engine making any knocking sounds? how many miles? What type of oil did you put back in?
Old Feb 1, 2014 | 08:20 PM
LannyL81's Avatar
Metal flakes in the oil....I would be concerned...but what to do at this point is the question?
Change the oil/filter and drive it for 1000 miles or so, then drain oil and check again?
Pull the distributor out and check the drive gear for damage?
Do a compression and/or leak-down test on each cylinder?
Let's see what others have as suggestions.....
Old Feb 2, 2014 | 12:38 AM
step66's Avatar
You need to provide known mileage on engine,and as rich asked for more detail. Does not your unit have a magnetic drain plug? I thought they were stock. Anyway,it seems that you are past the point of just weak bearings;oil consumption? Noise? Any idea of the maintenance history? How is the oil pressure? And,how does it run? Even low mileage engines suffer from NEGLECT! I would do what Lanny said,even though you just changed it,obviously. Do not at this point use an engine flush product and do a compression test. That can tell you the condition of the real heart so you won't throw $ at ancillary issues that may not solve your problem! These motors generally last up to 300K on the 1st go-round if maintained properly. Let us know what you find.
Old Feb 2, 2014 | 02:33 AM
richphotos's Avatar
They can last far beyond 300k if properly taken care of.
So many things to check, like you said, mileage, how it runs, does it knock or tick when running.
Old Feb 2, 2014 | 12:16 PM
MoneyPit99BlazerLT's Avatar
MoneyPit99BlazerLT is on a distinguished road
That happened to me at 187k and 190k oil change (oil changes every 3000 miles its whole life). Engine seized, spun bearings at 193k.
Old Feb 2, 2014 | 06:32 PM
GaBear's Avatar
The Truck has 155K I don't know what Oil was in it but I put Castrol 5W30 in it. I plan on doing the oil again after 1000 Miles check it and see what materializes.
Old Feb 2, 2014 | 06:35 PM
GaBear's Avatar
No Ticks or Knocks.....YET
Old Feb 2, 2014 | 06:45 PM
Clancy Pell's Avatar
Clancy Pell is on a distinguished road
Small flakes that are found on the drain plug could be from the camshaft, engine block or other ferrus metal. On the other hand if they are not magnetic, they are likely scraped from the pistons. Either way not good news.
Old Feb 3, 2014 | 09:10 AM
GaBear's Avatar
That's what I'm affraid of.
