idles problems
Old Jan 1, 2008 | 02:43 PM
martinblazer95's Avatar
martinblazer95 is an unknown quantity at this point
Default idles problems
i have a 95 blazer when i turn it on it idles fine but after 1 minute or so it idlesrough and gets about 2500 rpm.then it drops back to about 1000 rmpand then it idles up and down and sometimes itwill die?
Old Jan 1, 2008 | 04:32 PM
Chevy Lover's Avatar
Default RE: idles problems
Sounds like a vacuum leak. Check all you're vacuum hoses and connections.
Old Jan 2, 2008 | 10:52 AM
*Moving to 2nd Gen Tech*
I would start by removing the IAC valve from the throttle body and giving it and its bore a thorough cleaning. Erratic idle like that can be caused by a vacuum leak, but even a vacuum leak should smooth out to a set RPM...
sparkie624
Aug 12, 2011 11:31 AM
hubert hefner
63
Mar 16, 2010 11:29 PM
Mxlt
Oct 9, 2006 12:46 PM
91Blazerblk
Sep 25, 2006 03:23 AM
ivannj
Dec 19, 2005 07:54 PM
