Idling issue
Old Mar 12, 2018 | 12:56 PM
rwomer's Avatar
rwomer is on a distinguished road
Default Idling issue
2004 Blazer rwd 4.3 idle goes up and down. Map sensor or clogged air filter or possibly fuel pressure. Also there is a 1/4 inch vacuum line going nowhere
Old Mar 12, 2018 | 02:53 PM
jacked_72's Avatar
jacked_72 is on a distinguished road
I'd start with the vacuum line. Not much you can troubleshoot while a vacuum line is unplugged. Air filter is pretty easy to check, so that would be second.
Old Mar 12, 2018 | 03:18 PM
Mike.308's Avatar
What are Your fuel trims?
Old Mar 17, 2018 | 09:41 AM
jimspahr@msn.com's Avatar
Check the IAC device. Clean the Throttle plate with 3M intake manifold cleaner, not carb. cleaner. Vacuum lines are important as someone has recommended.
J.R. Clay
Mar 4, 2011 03:13 PM
InsaneIceCarver
Oct 18, 2009 08:56 PM
chevyracing95
21
Apr 20, 2007 03:10 AM
ware8083
Jan 1, 2007 12:37 AM
jim8264
Jun 19, 2006 01:37 PM
