ignition
Old Oct 19, 2014 | 04:44 PM
FUN-V's Avatar
FUN-V is on a distinguished road
Default ignition
OK here's the story.
I bought a 96 blazer that needed head gaskets, put everything back together, charged the battery over night, changed the oil, filled the coolant, etc.
new ignition(coil, ICM, Cap, rotor, wires) and I'm getting a weak spark from the wires , tested spark from coil=strong,
tested spark from plug wires=weak and almost non-existent
Any ideas?
Old Oct 19, 2014 | 05:03 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
Get a/c delco cap and rotor nothing else is good on our blazers
Old Oct 24, 2014 | 06:14 PM
FUN-V's Avatar
It turned out that the pick up coil was bad too
Old Oct 24, 2014 | 06:36 PM
burned's Avatar
burned is on a distinguished road
Pickup coil? Are you meaning the crank sensor?
Old Oct 24, 2014 | 07:24 PM
FUN-V's Avatar
Yah, the same part was listed under both the pick-up coil and crank sensor.
Now it won't start with the Mass Airflow Sensor plugged in and there is a knock that has turned out to be a bent rod, probably from the pressure of the coolant that was in the cylinder on top of the piston....uggghh
When I bought it, it seemed like a good deal, $1,000 with only 154,000 miles on it and all it needed was a head gasket. Well, I tear it down and both intake manifold gaskets leaked and there was coolant in the #5 and #6 cylinders. Now about $250 later after gaskets of all sorts, new ignition parts oil, coolant, plugs and now new push rods I'm starting to think not such a good deal.
Just frustrated, thanks for listening.
Old Oct 28, 2014 | 04:17 PM
Your 96 doesn't have a pick up coil, what part did you replace, (where is it located on the engine)?
Old Oct 28, 2014 | 11:29 PM
FUN-V's Avatar
on the back of the distributer, if not a pick-up coil then probably the crank position sensor
Old Oct 29, 2014 | 10:16 AM
burned's Avatar
That would be the cam sensor. The crank sensor is located at the front bottom of the engine.
Old Oct 29, 2014 | 04:47 PM
Yup, camshaft position sensor is in the distributor, and it can not cause a no start condition, (the engine will start and run with the sensor disconnected). After replacing the sensor, camshaft retard must be checked/adjusted using a capable scan tool.
Brian5792
Oct 24, 2018 11:34 AM
Jim Tunstall
Oct 14, 2009 01:47 PM
trettifire
Oct 3, 2009 08:48 PM
RichieTwo
Aug 12, 2005 11:30 PM
02 Vortech
Engine & Internal
Jul 8, 2005 08:47 AM
