ignition problems
Old Oct 18, 2013 | 06:42 PM
Debschevy's Avatar
Debschevy is on a distinguished road
Default ignition problems
I have a 2003 Chevy Blazer that has an intermittent ignition issue. whats happening is every once in a while i turn the key the dash lites go on the radio go on but the car doesnt crank then all of the sudden it engages and starts
it starts a number of times then nothing any thoughts
Old Oct 18, 2013 | 09:01 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Sounds to me that u are experiencing the common ignition switch issue.... I would guess u need to replace the ignition switch harness! Good news there is a sticky on forum showing u how to complete the task
Old Oct 18, 2013 | 09:04 PM
07nhbpsi's Avatar
I replaced mine, if memory serves me right the harness was 80.00 & took an hr or so to complete.
Old Oct 18, 2013 | 09:39 PM
Debschevy's Avatar
Thanks for your feedback, i did replace the ignition switch, but that wasn't it i had it towed into a mechanic and when it got there it started he kept it 2 days trying to repeat the problem but it didn't happen so i brought it home. any other suggestions
thanks
Old Oct 19, 2013 | 12:40 PM
Make sure the battery cable connections are clean & tight. Remove the bolts from the battery. Remove the bolts from the eyelet terminals, (pry the rubber insulators enough to remove the bolts). Clean the bolts, the eyelet terminals and the battery with a wire brush. Reassemble and make sure the bolts are tight.
Check the engine ground connection. Follow the negative battery cable from the battery down to where it connects to the engine block. Take it apart and clean with a file or wire brush.
Check the positive battery cable connection at the starter, and clean & tighten that as well.
Post your results, and we'll continue with diagnosis if necessary.
Old Oct 19, 2013 | 12:50 PM
Debschevy's Avatar
Thanks captain hook did all that i'll let you know if thats the solution
Old Oct 20, 2013 | 08:06 PM
my1997blazer's Avatar
my1997blazer is on a distinguished road
Hi. I had the exact same problem although sometimes dash light and no crank, then other times no dash lights but would crank. Either way the truck would not start. I pulled and cleaned all the ignition switch contacts put some dielectric grease in there and I have no problems since then. Its a bit of a fiddle getting it back together but saved some cash which I like cos I'm cheap.
Brian5792
Oct 24, 2018 11:34 AM
Milwaukeedude
Oct 14, 2009 10:48 PM
TBoneMM
Aug 26, 2009 08:11 PM
upblazer95
Apr 4, 2009 08:27 PM
s10 blazer dude
Mar 16, 2009 09:49 AM
