Ignition Switch - Pink Link Power Lost
Old Apr 4, 2009 | 02:56 AM
CallmeIshmael's Avatar
CallmeIshmael is on a distinguished road
Default Ignition Switch - Pink Link Power Lost
Hi there
first ,,english is not the common language i use,, so ,,parden me for any wrong terms or false grammar !
My Car 97'er Chevy Blazer ( Canada Import )
a few days ago my car came up with several signs like ,,,flickering 4 WD lights for a few seconds at another day during driving the speedometer went down and came up ,,,and in the Final ,,,i want to Start the Engine ,,,and it came up with nothing ,,,the Engine did not start !
more Information
the Car has a TEC-TUS 1 Immobilizer !
Startup Procedur ,,,,deactivate the Immobilizer and than start the Engine ,at this Point i came to the conclusion that the Immob is down and has a malfunction ,,,so i rebuild the wiring and removed the Immobilizer ,,,,( during removal ,,,the Batt was not connected ) !
The Test was ok ,,,the Engine started up and i was the Master of the Universe ,,,,for 10 Minutes !!!
The next Time i want to start up the Engine ,,,nothing !!!
ok ,,,could be a Fuse ,,checked the Fuses at the Fuses Bay ,,,,all are ok !
the Fuel Pump is working ( checked at the Terminal )
the Fuel Pump Relay ( checked ,,,ok )
Measuring the Wiring at the Ignition Switch ,,,and i found the Pink Link is not Hot !
To test the Function ,,,i get a hot wire (+) and connected it with the Pink Wire ,,,,and i started the Engine !!
My Conclusion now ,,,to get the Engine running ,,to put a Switch between
(+) and the Pink Wire !
the Ignition Switch has 5 Positions
ACC
Lock
Off
On
Start ---in this Position the Starter fails ,,,and i only make it running when i put (+) on the Pink Wire !
so far ,,,,,i came to the Conclusion that the Ignition Starter is down !
is this right ,,,,,or are they other mystical things ????
btw. i am not are Car Mechanic ,,,, i am just a user of a nice Car !!
Greets Ishmael
Old Apr 4, 2009 | 11:07 AM
So ,,,,i made it by my own !!!
I installed a switch , between the red wire and the pink ,,,and it runs , in the meantime i will order a new Ignition Starter !
Thx for reading ,,,,greets from Germany !!!
Old Apr 4, 2009 | 04:17 PM
Sure sounds like you have a bad ignition switch.
Old Apr 4, 2009 | 05:34 PM
I agree, faulty ignition switch. Faulty ignition switches are common on 1997. Very good English too...my German is not so good!
Old Apr 5, 2009 | 01:18 AM
Thx for obtainig the approval !!!
i was not shure abaout ,,,,and i am afraid of doing wiring things at my car ,,,,cause i haven't any clue abaout ,,,,but i have a technical ambition to fix my Problems by my self ,,,instead of running to a Mechanic ,,,and feel his hands in my pockets !
and driving an American Car in Germany is allways a little bit difficult ,,,, when the car runs ,,,it is an eye catcher ,,,when its broken ,,your lost in space !
to complete the thread ,,,, here is the link to remove the IS !
https://blazerforum.com/forum/article-submissions-discussions-47/how-ignition-switch-replacement-discussion-thread-26553/
greets to you guys
i allways was a Rangers Fan and i love Kid Rock
Old Apr 5, 2009 | 05:46 AM
Yep, that thread will guide you through it all. There are other tech articles that will help as well. The book method of replacement is posted along with the passlock relearn procedure.
celteagle
May 28, 2014 01:27 PM
poertsch
Apr 11, 2014 11:31 PM
scphill34
Apr 22, 2013 08:59 PM
Bowers
Mar 7, 2011 03:41 AM
monti72
Jun 19, 2010 05:06 AM
