Ilink 400 full system scan tool
Old Aug 20, 2019 | 08:47 AM
GreenBlazer2002's Avatar
Originally Posted by perumotors1369
Leave your foot on the brake?
Good catch! Indeed I did remove my foot from the brake pedal as my Blazer is an automatic and apparently my feet were on auto pilot. I ran the procedure this morning successfully!
Just remember to keep your foot on the brake pedal WHILE you accelerate. It feels wrong to do it but it works. Fuel cutoff was at exactly 4k rpms, as stated in the instructions.
Old Aug 20, 2019 | 08:55 AM
Good to hear. Besides that, how do you like that scanner? It looks like it's about the least expensive one that will do what it does, so I think I'm going to probably buy one.
Old Aug 20, 2019 | 08:58 AM
LesMyer's Avatar
Great! Did you get a chance to look for the ABS bleeding capability and the cam sensor retard reading?
Old Aug 20, 2019 | 09:31 AM
LesMyer's Avatar
I went ahead and ordered one off Amazon. Was $160 + got a 10% off coupon = $144 + tax (free ship). Sending my Foxwell NT630 elite back (which did work for ABS bleeding at $139, but does little else other than ABS and SIR). I'll review the I-link 400 when I get it.
Old Aug 20, 2019 | 01:13 PM
It appears to do everything except flashing. I paid $156 on Ebay. Came preloaded with GM.
Temporarily unlocked a radio I bought from the boneyard. Research said it couldn't be done, which is half right. As soon as I cycled the key it locked again. But at least I was able to verify that it worked. Seems to be a good deal for what it does.
BTW, I went to the ilink400 website and it was actually listed cheaper there. Like $119.
Old Aug 20, 2019 | 02:07 PM
LesMyer's Avatar
Sounds like a really good deal.
Old Aug 21, 2019 | 09:03 AM
I had thought that doing the cpk relearn would correct it to 0°. It's still showing-12°. What's the fix for this? Replace distributor shaft and timing components?
Old Aug 21, 2019 | 09:04 AM
File out the hole in the distributor hold down so you can rotate it a little.
Old Aug 21, 2019 | 09:07 AM
You've done this?
Old Aug 21, 2019 | 09:08 AM
Yes, sir. I had to do it on mine a couple of weeks ago. It doesn't take much, so don't go crazy.
Also, make sure you're checking it at over 1000 rpm.
