Initial timing 4.3
Old Jan 28, 2020 | 12:46 AM
  #21
Nola 77's Avatar
Nola 77 is on a distinguished road
yesi have spark at the coili think i know what i did after getting it to the compression stroke number 1 i turned the crank pulley by hand to line up the marks but i turned it counter clockwise because that mark was closest to the notch i should've turned the engine clockwise and i believe that was my mistake
Old Feb 4, 2020 | 06:04 PM
  #22
Nola 77's Avatar
Default its alive
i mustve done the procedure a dozen times marks lined up rotor pointing to the 6 and everytime it was audibly wrong i finally got the no1 cylinder at the very beginning of the compression stroke rotated the crank clockwise until the mark lined up with the timing cover and obseved that the rotor was still pointing at the 6 at this point I thought t myself it has to be close but still sounded like the starter was fighting compression so I took a chance and backed it up 1tooth bolted it back in and she fired right up
Old Feb 6, 2020 | 03:56 AM
  #23
Glad you got it! I had a pain in my **** when I was trying to get my distributor back in after my LIM gaskets...
Old Feb 6, 2020 | 06:04 AM
  #24
Mods's Avatar
For me on my what i believe is an 01 block the distributor will only go in correctly on TDC compression, If the marks are aligned on exhaust stroke it will be offeset by a tooth and wont line with the #6 mark. Either way if its running now then good stuff.
Lakings00
Apr 7, 2017 04:38 PM
bobs99
47
Feb 4, 2017 02:27 PM
ChevOeat
Oct 13, 2012 10:56 AM
ctys20
Jul 31, 2011 06:33 PM
Camarobird91
Jul 12, 2010 08:30 PM
