install brake booster
Old Sep 15, 2008 | 07:56 PM
brian szlis's Avatar
brian szlis is an unknown quantity at this point
Default install brake booster
Has anyone ever installed a brake booster . any tips that wouls make the job easier?How difficult of a job is this?
Old Sep 17, 2008 | 02:13 PM
AJBert's Avatar
Default RE: install brake booster
It is a pretty straight forward job, with the exception of one nut. You will need to grind down a deep well 15mm socket to about 1 3/4" to get the upper right hand nut off. You will also need a universal and extension(s). I would highly recommend using 1/4" drive due to space limitations under there. Also, you should be able to just unbolt the bracket from the wheel well for the ABS module and not have to disconnect any of the lines.
To make life much easier on you when installing the new booster I'd highly recommend cutting that upper right hand stud before installation. You'll understand why once you get the old one out.
Old Sep 20, 2008 | 12:08 PM
thanks for the tip,it only took 3 hours not bad .the top right didn't give me a problem as much as the bottom right ,but thanks again that little bit off the socket helps out.
Old Sep 20, 2008 | 03:17 PM
AJBert's Avatar
Glad I could help!
ndekens
Nov 29, 2007 05:33 PM
whistle
Nov 20, 2006 12:42 PM
consernedguy
Nov 6, 2006 11:19 PM
JCG1
Suspension Tech
Sep 19, 2006 02:07 PM
khalid_20879
Jan 3, 2006 01:00 PM
