Intake manifold leak
Old Nov 7, 2012 | 06:03 AM
mmmrodge's Avatar
mmmrodge is on a distinguished road
Default Intake manifold leak
I know I have a small intake manifold coolant leak. Its coming out of the exterior of the engine and running down the back. Would this type of leak also cause my vacuum leak issues?
Old Nov 7, 2012 | 09:38 AM
Rottidog's Avatar
Doubt it, the coolant system doesn't have anything to do with the vacuum system.
That being said, the manifold may be leaking elsewhere & the vacuum does come from the port behind the throttle body.
Get some brake cleaner, let the engine idle & spray the vacuum lines. When the idle changes - you've found a leak. Also check the line to the vacuum canister ball thing (if equipped) or the canister in the DS fender well. Then the line to the cab & in the cab to the HVAC controls.
Old Nov 7, 2012 | 10:05 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Nothing to do with vacume
Thats Ironic though my neighbor picked up a 1998 jimmy cheap thats leaking the same way.The guy who sold it thought it was head gasket
Old Nov 7, 2012 | 10:34 AM
Diaita's Avatar
it won't cause it, but may another symptom of the same problem. the plastic reinforced intake gaskets are quite brittle when they get older. make sure it isn't allowing coolant into the intake valley and contaminating your oil. it could have other cracks that are causing a vacuum leak.
Old Nov 7, 2012 | 11:51 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
In another amazing coincidence I bought my 1998 Jimmy from a guy who thought the head gasket was bad. I told him it was most likely the intake manifold gaskets but he didn't believe me. I got it for $1200.
Old Nov 8, 2012 | 01:26 AM
Diaita's Avatar
Lol. I had to change the gaskets in my 96 about 2 years ago. 14 years it is!
Old Nov 8, 2012 | 06:56 AM
mmmrodge's Avatar
thanks guys. I think i have isolated my vacuum leak to my HVAC system, i thought for a minute that it might be related to my 4wd issue. I did a number of tests after replacing most of the vacuum lines. Off to the shop to see if they can figure out this noise coming from my 4wd system. damn
my intake gasket doesnt leak too bad. i tightened the bolts a little about 2 years ago and it has been pretty good *knocks on wood*
sh1520
Oct 29, 2008 06:05 AM
hoffy015
Dec 19, 2007 09:20 AM
pilgrim
Engine & Internal
Nov 14, 2006 02:06 PM
blazerdan
Jul 14, 2005 12:51 AM
00blazer
Mar 30, 2005 12:24 PM
