Intake manifold questions
Old 10-04-2011 | 02:38 PM
Mike98Blazer's Avatar
^^^ what he said. 98002T set is correct. It's $61 and some change at rockauto and if you search the interwebz you can usually find discount codes to get an extra few bucks off as well. Just FYI
Old 10-04-2011 | 04:46 PM
cdmcg's Avatar
cdmcg is on a distinguished road
Cool, thanks, yeah I canceled that order. I guess when amazon asks for your year/make/model that doesnt effect what it shows you....good to know.
Old 10-10-2011 | 07:23 PM
cdmcg's Avatar
Ok, so, completed this on saturday with out any real problems. Except as we were finishing up, we found a plug that was not connected and could not figure out where it went. So I just finished everything else and turned it over and within a minute I had a p0118 code. So, we found where it plugs in and got that hooked back up. So, everything seems fine except if I turn the key over but do not start the car is still shows the code as well as my evap and catalyst system are not ready. Once the car is actually running my SES light is not on but the code is still stored. If I try to clear the code it just stays stored in system. Not sure how to officially clear this. Also, I need to figure out those two systems because I need to get smog checked asap.
Old 10-10-2011 | 09:07 PM
THe not ready will clear after a certain number of drive cycles. as will the p0118 code as long as no more instances occur.
Old 10-11-2011 | 12:03 AM
cdmcg's Avatar
Ok, cool. I just found it odd that the code wasn't tripping the light but was still stored. Thanks for all the help.
99blklt4wd
12-15-2011 05:00 PM
athens
12-29-2010 07:01 PM
rpishoman
Headers, Intake, & Exhaust
12-03-2005 01:58 AM
blazerdan
07-14-2005 12:51 AM
00blazer
03-30-2005 12:24 PM
Quick Reply: Intake manifold questions
