Intermittent AC
05 blazer, when i turn on my ac it usually works and blows cold for a few moments and then a ‘cheep’ like sound comes out of the compressor area and the cold air stops and it blows warm, if i rev to about 3k rpm’s the cheep happens again and the ac starts blowing cold for a few more minutes. i’ve read a few threads but can’t seem to find anything like this happening. any advice is appreciated
I didn't know that, good info! Usuallu I just add a can, I might try the AZ gauges next time.
Yep, sounds like low refrigerant. After it drops below a certain psi, it'll start working intermittently, until it loses a bit more and stop altogether.
Common leak points for these are the shrader valves on the low side, high side, and behind the cycling switch on the dryer. The o-rings flatten over time and fail.
Good luck!
MustardTiger1337
Aug 7, 2017 04:38 PM
ExplicitYourSelf
Mar 23, 2010 07:17 PM
