Intermittent Airbag Light
Old Apr 1, 2017 | 10:43 PM
  #31
TMM217's Avatar
TMM217 is on a distinguished road
Thanks those are 26109700. The one I need is 26109701. I can always go without radio controls I guess. Seems the 701 is a rare one.
Old Apr 2, 2017 | 09:10 AM
  #32
Strangerock's Avatar
Strangerock is on a distinguished road
thanks , thats good to know since i have radio controls on the wheel also. Do you have any cross reference numbers ? , it seam s there are some they say fit and the number is totally different.
Old Apr 2, 2017 | 10:42 AM
  #33
Vahomboy's Avatar
Vahomboy is on a distinguished road
I got a clockspring from a member one time and the connector/plug under the dash was different. I had to cut the wires and put my connector on it. I soldered and heat shrinked the connections/wires and it worked fine. You might have to do that. I also had radio controls. 2002 ZR2 Blazer.
**The wire cutting and changing plug was for the air bag and not the radio.**
Old Apr 2, 2017 | 12:17 PM
  #34
Awesome Vahomboy , do you happen to remember if the wires were colored the same ?. Did you have to change both plugs ?.
Old Jan 15, 2018 | 04:58 PM
  #35
Besel53's Avatar
Besel53 is on a distinguished road
Since I can't post anything new, guess I'll post here.
Had my airbag light on and steering wheel volume controls not working, so after checking continuity in all my wires, I found my clockspring to be bad. Sure enough, ribbon cable is sheared off. Attempting to repair since I'm having a hard time finding a new or used one. Wish me luck. Hoping it will fix the airbag issue...
Old Jan 16, 2018 | 02:44 PM
  #36
Besel53's Avatar
Default Success
Repair of the clockspring wiring is a success! Was very careful in stripping and soldering the wiring. Proper re-assembly is KEY. You MUST put it all back together right, and have the assembly centered before re-installing. I tested it BEFORE hooking everything back up, and spun the wheel both ways multiple times before a final continuity check through the clockspring. Hooked everything back up, and airbag light is now OFF, and radio controls work.
Old Dec 14, 2023 | 12:48 PM
  #37
Tbursh's Avatar
Tbursh is on a distinguished road
Just this morning I just unplugged and re-plugged the airbag sensor (Front LH) and the airbag light is gone! Maybe some corrosion or something in there. Just slid it out and in a few times to re-establish solid connection. I had an intermittent issue, driving it would go off and then stopped it would come on only sometimes though. Also when you revved the engine in park it would pop on and then go off. Same code 0036.
Jonboy
Mar 12, 2012 07:08 PM
gscrippler
Jun 7, 2009 08:53 PM
aaronjohn20
Mar 21, 2008 07:00 AM
mdehoogh
Aug 10, 2007 07:54 AM
hotrod28
Nov 4, 2006 08:11 PM
