Intermittent heater - cold/hot
Old Dec 29, 2010 | 06:03 PM
The blend door should cycle to its limits. If it doesn't, the actuator is likely faulty.
If you don't have the $$ for a new one, you may be able to find a used one at a junkyard.
Old Jan 5, 2011 | 08:26 PM
rigger's Avatar
rigger is on a distinguished road
New guy to post. Having similar problem, I noticed we have hot air. Turn to blue range still hot air. Switch off still hot air. Only difference when using the fan. Blue red off. After cool down all worked well. Listened for vacuum switch and could hear changes. After road temp reached "Not" working again, hot air. Are airdamns getting worn???
Old Jan 5, 2011 | 08:30 PM
rigger's Avatar
Originally Posted by kaschenberg
I think I found my answer:
The battery was recently replaced in the car which I heard can make the problem worse, and it did. The ecu calibrates the actuator whenever power is lost (changing battery) and causes the problem to escalate further.
This stupid part is about $100-$150 and can be changed from the glovebox by removing two 5.5mm bolts via box-end wrench apparently.
Thanks!
What is the acutual name of the part or possible P/N
Old Jan 28, 2011 | 04:32 PM
mechelle207@yahoo.com's Avatar
mechelle207@yahoo.com is on a distinguished road
I have a 1999 Chevy Blazer and I am having the same issue. What I would like to know is if the Actuator would be as easy a fix on the 99 model as it would be on a 98? I live in Maine and where it is January and VERY cold here I would like to be able to get this fixed ASAP. I went to a dealer and was told the whole dash would have to be taken apart to get to it as opposed to through the glove box. Anyone here have any info that would be helpful?
TIA
Old Jan 28, 2011 | 06:20 PM
blazinloud's Avatar
yes it will be the same from probably 95-05
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
as2higpark
Oct 18, 2007 12:18 PM
outdoorxman
15
Jun 12, 2007 05:06 PM
