intermittent scrapping sound from rear brakes
Old Dec 20, 2007 | 07:17 PM
Kaffeene's Avatar
Kaffeene is an unknown quantity at this point
Default intermittent scrapping sound from rear brakes
I have just noticed an intermittent scraping sound from the rear passenger side wheel. Sounds like scraping on the rotor. It may also be coming from the driver side rear wheel but it is definitely coming from the passenger side. I havn't inspected it yet since I just discovered it. I just wanted to get some opinions on what it could be or what it most likely is.
I'm guessing, warped rotor or wheel bearing or some other thing causing friction at the same pointof every rotation of the wheel. It's most noticeable at lower speeds but goes away when I apply the brakes.
Ideas?? thanks
Old Dec 20, 2007 | 08:32 PM
Default RE: intermittent scrapping sound from rear brakes
Most likely is being caused by the spring clips on the caliper brackets. As the outer edge of the rotor rusts, it will stick out further and sooner or later it will rub.
Old Dec 21, 2007 | 06:34 PM
Hanr3's Avatar
brakes.
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
lowblazin
Lowering Tech
Nov 26, 2007 08:20 AM
