Introduction and need help please
Old Apr 16, 2019 | 06:50 AM
Kodieking206's Avatar
Kodieking206 is on a distinguished road
Default Introduction and need help please
Hi my names Kodie from auburn Washington.
I bought a 97 blazer first one ever owned that’s Starts up revs to 3000 rpm for about 3 seconds then Boggs down and dies after I’ve replaced the map sensor, maf sensor, tps sensor and about to replace the fuel filter.
i was wondering if anyone else has had this problem and id they have any advice that could help
thank you for your time
Old Apr 16, 2019 | 07:20 AM
Timmins_Jimmy's Avatar
Timmins_Jimmy is on a distinguished road
Welcome,
Fuel Pump?
do you have pressure from pump?
Other will chime in shortly with suggestions
Old Apr 16, 2019 | 07:34 AM
go chevy's Avatar
Welcome to the Blazer Forum...
Old Apr 16, 2019 | 08:46 AM
cleburne red's Avatar
First, welcome to forum!
Second, go ahead and check your fuel pressure before you throw anymore money at it. There's some really good write ups on here on how to do it.
Are there any trouble codes present? Cel on?
Old Apr 16, 2019 | 09:56 AM
rriddle3's Avatar
*Moved thread to '2nd Gen tech'*
Old Apr 16, 2019 | 06:50 PM
I will look at the fuel pressure and it showed no codes which I thought was weird
Old Apr 16, 2019 | 07:34 PM
There's no codes for low fuel pressure, per se, but I've often noticed a P0300 when my pumps were going out. Probably just from the misfire as a result of running super lean, since the pump couldn't keep up
Old Apr 21, 2019 | 08:39 AM
LannyL81's Avatar
Sounds like the MAF sensor is not plugged-in; check the connector for it.
Old Apr 21, 2019 | 09:06 AM
OP said he replaced the maf, quite possible it's not plugged in all the way. Mine doesn't have a maf, so I'm not familiar with the symptoms
Old Apr 21, 2019 | 10:16 AM
GeorgeLG's Avatar
