Jumping the solenoid
Old Mar 9, 2018 | 10:49 PM
Sdurreman's Avatar
Sdurreman is on a distinguished road
Default Jumping the solenoid
Was having an ignition issue on my 2000 Chevy Blazer LS. All the symptoms lead me to believe it's a starter issue. I take off the starter and have it tested twice at the parts store. It passes both times. Put the starter back on and hook up the battery to a jump box and it fires right up.
The next morning I go out and it's giving me the same symptoms. Pull the battery out to have it tested and it tests good also. Hook it back up and still same problems. While trying to verify contact on the solenoid, I bypass it entirely and the starter motor engages. After jumping the solenoid I've started it with no issue a half dozen times.
Should I trust the machine at the store? If I had to jump the solenoid does that mean the starter is definitively defective?
Old Mar 9, 2018 | 11:03 PM
AJBert's Avatar
Take a look at your ignition switch, not the cylinder.
Old Mar 10, 2018 | 08:02 AM
jacked_72's Avatar
jacked_72 is on a distinguished road
You haven't said what the symptoms are, but if it's not cranking, I agree the switch could be the problem.
Old Mar 10, 2018 | 09:24 PM
Sdurreman's Avatar
After jumping the solenoid, it will crank over with the ignition switch if (when) it happens again I'll start with the switch.
Tony H
Jan 21, 2011 10:11 AM
Tony H
Feb 23, 2010 08:09 AM
god_zilla00000
14
Jan 5, 2010 05:26 AM
soul_seeker77
Mar 11, 2007 04:41 PM
Hanr3
Mar 2, 2007 11:32 PM
