Just bought a 2000 Blazer....any advice?
Old Sep 18, 2012 | 02:26 PM
connor10ersftw's Avatar
connor10ersftw is on a distinguished road
Default Just bought a 2000 Blazer....any advice?
I just recently purchased a 2000 chevy blazer from a used dealer. I'd love to keep this car for a good amount of time and wanted to check up on any issues that need to be addressed with this cars mileage. The car is cruising at 190k miles. It's the 4WD variant. When i bought the car we had a little bit of work done. To be honest, im not sure what the exact problem was that was fixed but i believe they had done some engine work and didn't properly mount everything. Also did the basic oil change.
1. What kind of fluids should i change?
2. Any engine issues i should be aware of? (i believe its a v6 car is not here at the moment)
3. Transmission i believe is original.
4. Suspension is a bit bouncy
overall car sounds ok, starts a bit rough but havent had any issues.
I appreciate the tips in advance!
Old Sep 18, 2012 | 02:34 PM
rexmburns's Avatar
Super Moderator
Best advice I can give is grab some beer and start flipping through the forum!!! All of the things you mentioned have been covered on here
Old Sep 18, 2012 | 03:33 PM
warthogdriver's Avatar
^^^+1
also biggest thing i can think of is the intake manifold gasket...these engines love to chew them up and spit them out. if it hasnt been changed out be aware of its condition. search the forums....you will see it is very common issue. once fixed correctly though you should be good to go for the long haul.
Old Sep 18, 2012 | 05:26 PM
4x4blazerguy's Avatar
Why not drive & enjoy it. When problems come up deal with them then.
Old Sep 19, 2012 | 08:55 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Any new vehicle I buy I do a good tune up. I would also have the trans serviced, front and rear diffential serviced, transfercase as well. Check your coolant system, if it's had dexcool and has seen air it could get clogged up.
Old Sep 19, 2012 | 09:50 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
And, any replacement fuel or ignition parts should be A/C Delco OEM. Otherwise, you will be wasting time and money. The vacuum lines are likely rotten if they have not been replaced. This can cause big problems with your HVAC and 4WD systems if they implode. As stated, read through the forum. You will find a wealth of info. Hope you get many trouble free miles on it.
Old Sep 19, 2012 | 12:03 PM
newguy's Avatar
Dont touch the tranny, I changed my fluid and it died 2 weeks later
Old Sep 19, 2012 | 12:51 PM
If you do anything add a B&M SuperCooler for the tranny. If you serviced your tranny & it went out it was most likely going to fail either way. Unless you unplugged a wire by accident.
phxjosh
May 28, 2013 04:09 PM
AcAlan
Nov 27, 2011 03:45 PM
pmzusmc
Mar 30, 2011 02:25 PM
muleman
Sep 28, 2007 02:07 PM
arbowman
Oct 17, 2006 04:39 AM
