Just stopped...
Old Apr 26, 2011 | 07:01 PM
Tutype's Avatar
Tutype is on a distinguished road
Default Just stopped...
Started 96 Blazer w/no problem, drove it approx a half of block and it shut off, and would not restart.
1. I cecked the fuses located on the side of the dash, which are all fine.
Can anyone tell me the location of any other fuses, 'cause I noticed I don't here the fuel pump humming anymore?
She cranks, but no start...fuel pump replaced (don't know brand a shop replaced it) about 4 years ago.
Any help/advice is greatly appreciated.
-TuType
Old Apr 26, 2011 | 07:20 PM
warthogdriver's Avatar
if its cranking and you have power, cant hear pump....it just might be pump.
there is a fuel pump relay in the power block on driver wheel well.
might check that out....i dont know how you check for a bad relay though.
did it sputter at all or act like it was running outta gas....or has the fuel gauge been going all over?
this sounds like what happened to me, i was driving down road and then engine stopped...would crank all day long but not turn over.
i am sure there will be other people that will chime in, give time.
Old Apr 26, 2011 | 07:51 PM
kevlar974's Avatar
kevlar974 is on a distinguished road
I would check the relay too usually you can exchange one from another system if it has the same number in the same under hood fuse box. Could also check for fuel at the line just before it goes into the CFI. Proper way is probably a gauge and check the pressure but I use a small screwdriver to push on the needle valve just to see if I have anything for a quick test.
Just don't get any in your eye it comes out quick if you've got good pressure.
Old Apr 27, 2011 | 12:06 AM
rriddle3's Avatar
That won't tell you if you have enough fuel pressure to start the engine, which requires 55-60psi. Get a fuel pressure gauge, connect it to the schraeder valve on the fuel intake line behind the throttle body, and follow the steps in 96+ Fuel System Diagnosis.
Old Apr 28, 2011 | 03:08 PM
Tutype's Avatar
where exactly are the relays located, and are they labeled?
Old Apr 29, 2011 | 10:29 PM
Tutype's Avatar
It was the pump. Changed sending unit...Thanks everyone.
DaveHearne
Jan 1, 2013 09:25 PM
ifght4u
Aug 2, 2012 03:46 AM
pinecone
Jun 13, 2011 05:59 PM
FarmgirlINmi
Apr 28, 2010 05:36 PM
swisstom
Jul 3, 2006 12:39 AM
