Key Stuck
Key Stuck
I have a 2002 ZR2 auto and the key will shut the engine off but it won't turn and come out. There is a hole in the steering column that if I stick a pen up in it then the key releases.
Is there a missing button that goes in that hole? I've also been told that there was a cable that ran to the transmission shifter that can be adjusted to release the key - (couldn't find it) and that there is an electrical solinoid on the column that releases the key - (haven't looked yet) Any help here would be appreciated. Thanks.
OK, I checked the reverse lights and they are working fine, but the key still gets stuck.
Do you have any check engine lights? Mine was doing this a few weeks ago, I replaced the ignition switch, runs from the ignition down the column and under the dash, easy fix, the part is about $100, I went to the junkyard and found 1, paid $8 for it, replaced and good to go.
It attaches to where the key goes in, if you pull your plastics off around the column, look at where the key goes in and you will see a little black box looking thing, its that, but there's wires that run down the column to right above the pedals, push ur key in a few times, almost bang on it and see if it will come out, I went a week having this issue, but if I hit the key in every time it would come out
well
I had this problem years ago..In fact, it is what brought me to this forum....My 01 Extreme had the key stuck in it...Turns out it was this anti theft lock deterrent thing....I removed this white plastic piece and have not had one problem with the key since....
changeme20
10-24-2020 02:12 AM
bigjblaze
10-19-2009 07:11 PM
trettifire
10-03-2009 08:48 PM
Woods1478
04-25-2008 08:57 PM
