Keyless entry
Keyless entry
how do you tell if your vehicle came stock with keyless entry,is it the code au0, if it is i have it and will this remote work
eBay Remote
eBay Remote
RE: Keyless entry
AU0 is the code for RKE. To know if that remote will work, you need to drop the lower hush panel on the driver side and have a look at the FCC number on the top of the module (located directly behind the DLC - data link connector). You need to match up the numbers (minus the R & T I believe which stands for Reciever and Transmitter respectively).
Fixed your long link too. You might also want to provide your vehicle information when asking questions of this nature. Putting that information in your signature and always attaching it to your posts will help out greatly!
RE: Keyless entry
I too am interestered in this. My 2002 Blazer doesn't have any remote with it but i think it bay have keyless entry. I know where the module is but whats the number i should be looking for? Thanks
RE: Keyless entry
It'll be on the label on the RKE module itself. The number you need to pay attention to is the FCC: ******** (unsure of the number of characters, but it's an alpha-numeric code).
RE: Keyless entry
Which Number says i have the Keyless entry and which one doesnt?
If i have the Code does that meen that i have keyless entry?
RE: Keyless entry
Did you miss it above??? The RPO code list inside your glove box shows all options originally installed on your vehicle. AU0 is the RPO code you need for factory installed RKE (remote keyless entry). If you do not have AU0, then you do not have RKE unless someone added it later on.
RE: Keyless entry
OK cool, ill look for it. Thanks.
RE: Keyless entry
Alright i just checked, i have AU3 not AU0, so thats a bummer.
93Miata
24
11-14-2005 10:09 PM
