keyless entry mod?
Old Jan 3, 2011 | 07:06 PM
mitchell93's Avatar
mitchell93 is on a distinguished road
Default keyless entry mod?
i have a 98 4D blazer, and it doesn't have key less entry, it would be nice if it did, and i was wondering if i could get one out of a junk bravada jimmy or blazer, what parts will i need, im thinking it would be the wiring for the doors, and some receiving unit, but idk were thats located at
Old Jan 3, 2011 | 09:54 PM
ABN31B's Avatar
if it's like everything else, it should already be wired in (power seats style)...
I dunno on this one though...
when you go looking for it, you will need a brain (behind the d side hush panel:
and check the FCCID to make sure you get the right key fob to program to it.
i did a search for RKE and came across some gems like
Adding RKE
and
Keyless Entry
there is a bunch of info in here
Old Jan 3, 2011 | 10:15 PM
mitchell93's Avatar
thats it right there? well its easy then right?
Old Jan 3, 2011 | 10:31 PM
ABN31B's Avatar
so long as you have the wire harness it SHOULD be plug and play with a programed matching remote
search it up though... it's uncommon for this to come up
Old Jan 3, 2011 | 10:37 PM
mitchell93's Avatar
ok, so its under my dash? i read somewhere just now its inside my drivers door... ima go look right now for wired, and i wanna know exactly were to look... and what the wired look like
Old Jan 3, 2011 | 10:49 PM
ABN31B's Avatar
use the pic above... if there is no box, but the harness is tucked up inside... then WIN!
in older vehicles... like say a 93 bravada, it would be under the cup holder 9from what i read looking for this for you)...
never saw it being in the door... maybe they were talking about the accuators that run the locks
Old Jan 3, 2011 | 11:17 PM
mitchell93's Avatar
ok, i looked were ur picture showed, i found a small connector with 2 orange wires and i thing a black wire with a white strip, is this it?
Old Jan 3, 2011 | 11:57 PM
ABN31B's Avatar
dunno...
LOOKY HERE
super useful thread from search
Old Jan 26, 2011 | 04:07 PM
mitchell93's Avatar
i swung my by local dealer Monday and asked them about this mod, he thought i was an idiot, and told me that if it didn't already have key less entry, there wouldn't be the wiring there for it, now i found something under there, and i think that what it is, so this will for sure work if what ur saying, im getting a receiver out of a 2001 jimmy, and i have a 1998 blazer... id like to do this, and if i can, i guess id have to find a different dealer to program it for me, cuz my local one, has no clue apparently...
Old Jan 26, 2011 | 09:14 PM
davedidit's Avatar
davedidit is on a distinguished road
Check your RPO code's in he glove box
the GM parts can run the VIN and print out all options or use
http://www.compnine.com/vid.phpr
if you have the option all you will need is the key fob http://www.yourkeylessremote.com/(S(...)/default.aspx
