Keyless Entry AND Seat Lever
Old Nov 11, 2010 | 03:28 PM
Shonda518's Avatar
Shonda518 is on a distinguished road
Default Keyless Entry AND Seat Lever
Hi Guys,
I'm sure I just over looked these topics, but need some help on 2 of my latest issues.
I have a 98 Blazer LS.....
1. Seat levers broke on both sides--Can I just pick these up at Autozone or do I have to order them online? Are they easy to install?
2. Keyless entry does not work- I bought the truck used and it never worked. Pretty sure it's the standard factory model. I already bought new batteries for the remote and still a no-go...Could it be disconnected, or fuse? How can I tell? I'm a girl, so not too handy under the hood, but I follow directions well..lol
Thanks for your help!
Old Nov 11, 2010 | 04:24 PM
rriddle3's Avatar
*Moved to '2nd Gen Tech'.*
Old Nov 11, 2010 | 06:33 PM
1998MSO's Avatar
1998MSO is on a distinguished road
You may need to program the transmitter(s). Here are instructions:
Transmitter Programming:
1)With the driver door closed, hold down the power unlock button on the door panel.
2)Turn the ignition switch to the ON position
3)Turn the ignition switch to the OFF position
4)Turn the ignition switch to the ON position
5)Turn the ignition switch to the OFF position
6)Release the power unlock button on the door panel.
The remote control door lock reciever will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1)Locking the doors
6.2)Unlocking the doors
IMPORTANT:
All extra transmitters must be programmed at this time. When a new transmitter is programmed it will deactivate the old transmitters.
7)Hold down the lock and unlock buttons on the transmitter until the remote control door lock reciever will respond in the following manner:
7.1)Locking the doors
7.2)Unlocking the doors
8)Repeat step 7 for each additional transmitter
9) Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
As for the recliner seat handles, this is common problem for these models and the best solution is too order these improved types:
http://www.wittydeals.com
Good luck!
Old Nov 12, 2010 | 12:17 PM
Shonda518's Avatar
Thanks 1998MSO, your instructions worked like a charm-Keyless entry now works.hmm now if I could only find the spare keys ....Next stop....seat lever .....
Old Nov 12, 2010 | 01:03 PM
1998MSO's Avatar
Glad that worked! Good luck on the handles. I purchased a pair a while back and did the trick, although I did end up cutting away a bit of the plastic trim to make it fit.
Old Nov 12, 2010 | 07:13 PM
g_mike's Avatar
g_mike is on a distinguished road
seat leaver is 1 screw, unless you have the problem i had and that is the plastic handle was fine but the metal rod broke....
Old Nov 12, 2010 | 07:57 PM
Shonda518's Avatar
Drivers side lever is still intact... Screw still there-that should be easy, BUT the passenger is broken off...the metal rod that sticks out from the seat looks broken and the lever itself broke off.The inside of the lever that broke looks totally stripped...Think that will be my problem child..
Hey G Mike....Where you able to fix yours? Thinkin' we may have the same issue......
inscarguy
Feb 24, 2019 02:56 AM
garryb
Aug 3, 2011 06:48 AM
njk53
Nov 16, 2010 09:39 AM
midnightbluS10
Aug 8, 2009 08:55 PM
Walleye
Feb 18, 2006 04:14 PM
