Leaky radiator, need help with replacing.
Old Jul 19, 2009 | 06:03 PM
oem95blazer's Avatar
oem95blazer is on a distinguished road
Default Leaky radiator, need help with replacing.
Hey guys, new to the site here. Just bought a 95 blazer a couple months ago. Theres a crack in the radiator and it inconsistently leaks after I drive and shut the motor off. I will be buying a new radiator and replacing it myself. My question is, how do I unscrew or undo the oil and tranny cooler lines that go in to the sides of the radiator? Can I take a wrench and just loosen it up and then pull the lines out or? Dont wanna damage the lines so any advice is greatly uprecciated!
Old Jul 19, 2009 | 06:06 PM
FlatTopFoley's Avatar
FlatTopFoley has a little shameless behavior in the past
I believe there's a little clip that holds the lines in, just pop it off with and they should pull out.
Old Jul 19, 2009 | 06:12 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Its Easy..Just unscrew the oil cooler and trans. lines from the Radiator fittings..those big fittings already come with the new radiator.
Old Jul 19, 2009 | 06:38 PM
Thanks for the prompt reply, you guys are quick! You know, thats what I figured, but wasnt sure. I gave it a little twist at first and it didnt budge so I didnt wanna break the line. Then posted here and thats what you guys reconfirmed had to be done. With a little more force I unscrewed the lines. Will replace rad this week. Thanks again for all the help guys.
blazen_red_4x4
Dec 24, 2014 07:09 AM
bigdaddykane93
Jan 4, 2010 12:03 PM
hhs2006
13
Feb 3, 2008 10:26 PM
Bojib
May 14, 2006 03:28 AM
2001Blazer4x4
Jan 2, 2005 02:18 AM
