LED Light Bar
LED Light Bar
Hey guys i need some help. i just recently bought a new LED Light Bar and it has white LEDs for the reverse light. except i cant get them to work...im trying to hard wire them intot he reverse lights in my tail lights but cant get them to work...help!
If you're trying to go right into one of your rear lights the reverse lights have a 2-wire connector. Backup lamp is lt. green & black ground. Look for a ziptied harness on the crossmember underneath the rear of the truck. If you have the trailer wiring harness it'd be easier.
ok well to wire the brake, R and L turn, and running lights i used the trailer wiring harness. so i used 4 out of the 6 wires. there were 2 wires left over but the directions didnt say to use them.
where is the wiring under the dash? specifically the thick dk blue for the rear feed?
good to know for the future S series i'll more than likely end up buying.
I dunno about "thick". Depending on what you're hooking up I have a feeling you did a good thing running your own wiring. To be honest I've never taken my own harness apart to look at it, I just splice a new 4 wire plug on every two years it seems.
