Left Blinker to fast??
Old Jan 14, 2012 | 06:02 PM
ABSLT's Avatar
ABSLT is on a distinguished road
So Ive checked all three bulbs that go when the left is on they are all fine, cleaned them, still blinks to fast, only on the left side, its happened a couple times before and i just bang on the left rear tail light lens and it fixes it, but not this time. Is there a separate relay for each side?
04 blazer 4x4
Also hazards blink normal, also i switched all left blinker bulbs to the right and the right ones to the left and it still has the issue
Last edited by swartlkk; Jan 14, 2012 at 06:48 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Jan 14, 2012 | 06:26 PM
pettyfog's Avatar
Check for change when you:
Cycle the hazard switch a couple times.
Remove bulb one at a time while flashing, when no bulb lights the bulb and socket in your hand is the good one, the one still in the socket has a bad ground/common or its socket common is bad.
- which happens a lot on Chebbies, I hear
Originally Posted by ABSLT
...i switched all left blinker bulbs to the right and the right ones to the left and it still has the issue
Good work.
Which would mean you will do the above to find the bad socket.
Long shot:
Remove the backup lamp that side
Old Jan 14, 2012 | 06:41 PM
ABSLT's Avatar
Good work.
Long shot:
I have pulled each bulb while they are flashing, all the other ones continue flashing with eachother, except for the one i pulled, so im not sure where to go next
Old Jan 14, 2012 | 07:04 PM
pettyfog's Avatar
Hmmm.. that's a real headscratcher. That leaves the front but it isnt usually and like you said, you rapped the back to fix it before.
I have known people who just went ahead and replaced sockets anyway.
Old Jan 14, 2012 | 07:06 PM
ABSLT's Avatar
Yea im not sure, i messed with the front ones and all is well there too. Very annoying this issue though. I have been not using it because its so annoying in the cab.
Old Jan 14, 2012 | 07:49 PM
pettyfog's Avatar
And just to be clear.. you never hear the flasher relay if neither the hazards or turn signals are on, right?
Old Jan 14, 2012 | 07:52 PM
ABSLT's Avatar
correct only turns on with blinkers or the hazards, never any other time, just goes double time when the left blinkers on.
Old Jan 14, 2012 | 08:08 PM
Blue Jay's Avatar
Blue Jay is on a distinguished road
A shot in the dark, do you have a trailer hookup? If so check it for green.
Old Jan 14, 2012 | 08:10 PM
ABSLT's Avatar
No i dont have a trailer hook up, but funny you mention it i bought the 4 pin plug, to install trailer wiring but never got around to it, and that wont happen now until i get this fixed
Old Jan 14, 2012 | 09:18 PM
gojorg's Avatar
Just my 2 cents, you mentioned you checked the 3 bulbs but there are 4, the side marker next to the headlights also works with the signals, when mine had 1 of those blown I was getting the hyper flash and it happened to be the left. Hope this helps.
