left front end squeaking
Old Jul 13, 2009 | 03:52 PM
blazernoobie's Avatar
blazernoobie is an unknown quantity at this point
Default left front end squeaking
Hello,
I have a strange squeaking on the driver side front wheel area every time i go over a bump.
This happened two days after going down a very bad dirt road.
is it likely i buggered up the suspension or could it be a grease issue?
any help is very appreciated.
Regards,
Blazernoobie
Old Jul 13, 2009 | 08:44 PM
chrisjanicki01's Avatar
chrisjanicki01 is an unknown quantity at this point
Default i think i might have your answer
sounds like a tie rod end or a wheel hub bearing assemly. both pretty easy to fix but the hub needs torque.
Old Jul 13, 2009 | 08:58 PM
You can spray the bushings with some lithium grease to see if that quiets down the sound. It likely will only be temporary if it does anything, but it will allow you to determine where the sound is coming from.
BassHog
Sep 22, 2014 01:47 PM
duckland23
Aug 12, 2012 07:39 PM
Coheed
Dec 13, 2011 10:46 PM
eknox327
May 16, 2008 12:33 PM
tpendergraft85
Feb 17, 2006 07:10 AM
