Left rear water leak
Old May 2, 2021 | 05:32 PM
puttster's Avatar
Default Left rear water leak
In the driver side rear corner is a box with fuel hoses going in and around it. Above those hoses is a nipple-like deal attached to body sheet metal. Water is dripping out of this nipple at a pretty good rate. I can't see what is on the other side. Any ideas?
Old May 2, 2021 | 05:50 PM
LannyL81's Avatar
Let me guess....you just filled-up the windshield washer bottle right? Check the carpet at the tailgate or lift gate....bet it is wet.
Old May 3, 2021 | 06:56 AM
puttster's Avatar
Carpet is dry though I did not check under the spare tire.
Bit t I thought the WW circuit was on the passenger side.
is the nipple just doing the job it was designed to do?
Old May 3, 2021 | 08:20 AM
LannyL81's Avatar
There is a WW connection under the carpet at the rear left side. Have to pop-up the trim piece to access it. Very common for this connection to come apart...it is just a push-on connection of the water line to the rear glass washer.
Depending upon how your Blazer is parked, the water could have just ran towards the left side.
Quick and easy to check.
That canister is the fuel vapor charcoal canister...no water in it. Now if that liquid is fuel...then that is a totally different problem.
jimmy_for_ever
Aug 26, 2018 05:42 PM
Charles Hines
Apr 21, 2013 06:27 PM
hitechracing
Nov 12, 2012 09:07 PM
tazz7002
Dec 23, 2011 09:28 AM
nomichblazer
Oct 28, 2008 09:20 AM
