Left Turn Signal Flashing Fast
Old Dec 28, 2006 | 05:51 PM
scottvwcars's Avatar
scottvwcars is an unknown quantity at this point
Default Left Turn Signal Flashing Fast
1999 blazer 4door 4.3l v-6, 4x4.
Problem - Out of the blue left turn signal started fashing fast like a bulb was burnt, not the case as far as I can see, bought a new flasher, also not the problem. Checked all fuse's. Non burnt.
Any suggestion on this problem.
Thanks
Old Dec 28, 2006 | 06:02 PM
hillbillyinOhio's Avatar
Default RE: Left Turn Signal Flashing Fast
my guess is that you have a bulb that is bad.some of them are dual filament. that would be my conclusion
Old Dec 28, 2006 | 06:20 PM
Dabber's Avatar
Dabber is an unknown quantity at this point
Yep check your bulbs
Old Dec 28, 2006 | 07:29 PM
So it is possible that the bulb will still work but one filiment be burnt.
I will give it a try as I am working on it right now in the garage on the 4x4 vacume lines. Trying to get the
4x4 to work again. One thing after another on these rig's, good thing for this forum..
Later
Old Dec 29, 2006 | 12:12 AM
yea, theya re dual filaments,. will look like it works fine, but the back ones are duals.
Old Dec 29, 2006 | 08:46 PM
Your right, checked the back middle bulb, bottom filiment was burn off and shorted on the arm. Still
working but shorted just the same. Oh well, I have a new flasher now also.
Thanks
SmokedGhouda
Dec 4, 2012 08:44 PM
patty benoit
Jun 27, 2011 04:22 PM
EXKid
Feb 7, 2011 09:19 PM
lionel2
Sep 19, 2009 04:14 PM
mrmack070
Jul 27, 2009 09:05 AM
