Limp Mode Nightmare
Old Dec 17, 2012 | 11:32 PM
2001BlazerLSCan's Avatar
2001BlazerLSCan is on a distinguished road
Question Limp Mode Nightmare
Hey to all, well I'm at a bit of a stump, so let me begin. got my 2001 Blazer LS 4x4 W/ Auto (NP8) scanned and got these codes: P0740, p0758, p0785, p1810, p1860, p0753. So after some reading on here I checked all my fuses, yup. Checked for power in fuse #11, Yup. Checked for power from the pink wire that goes to my transmission, Pin "E" I do believe, and I have power on ON / RUN from my ignition. Also note, my 4x4 isn't working as well, 4 button selector switch has it's illumination lights, but no selection lights. replaced the TCCM with no luck, and I am able to get 4x4 by bypassing the vacuum switch on the firewall with a hose joint. (tried a couple vacuum switches as well to make sure that wasn't the problem) Can anyone help me with this nightmare?
Old Dec 18, 2012 | 12:08 AM
xgiovannix12's Avatar
Old Dec 18, 2012 | 07:42 PM
I'm getting power to the pink wire going into the Neutral Safety Switch. Could this switch be the problem? if not, yeah might have to just replace this section of harness.
Old Jan 1, 2013 | 01:25 PM
well I'm down to 4 codes, P0740 P0753 P0785 P1860. Motor is running like a champ after I replaced the spider injector, but unfortunately still in limp mode and still no 4x4. tried 3 TCCM's and 2 4x4 switches. All fuses are good. Connections along the harness all look good as well. Changed 2 out of 3 O2 sensors, will change the last one and see if there is any difference. Any ideas, suggestions appreciated.
Old Jan 1, 2013 | 01:44 PM
Check the harness connector on the transmission: Right front corner, plugs in vertically just above the pan. This harness feeds all of the solenoids in the transmission. Due to its location, it's exposed to road slop, mud, sand, water, salt, etc etc, all of the things that promote corrosion. Clean it out, dry it out, and put silicone dielectric grease in the connector. Just a thought
Old Jan 1, 2013 | 02:49 PM
will try that today, thanks, will let you know the results!
Old Jan 1, 2013 | 05:50 PM
It was unplugged, cleaned and plugged it back in, but no difference
Old Jan 1, 2013 | 05:58 PM
With the engine at idle, check both terminals, (on top of the fuse, do not remove the fuses) of all fuses with a volt meter or test light, in both the underhood and instrument fuse panels. Post your results.
EDIT: Pay close attention to these:
Instrument fuse panel:
#19 RDO
#11 Cluster
#22 ABS
#15 4WD
#8 CTSY LP
In the underhood fuse panel:
ECMB
ECM1
ATC
BTSI
CRANK
Old Jan 1, 2013 | 08:56 PM
Update: ATC fuse must have burnt when I plugged in the harness to the tranny, replaced fuse, and 4x4 is working properly and excellent! still in limp mode tho, CRANK fuse shows no power @ idle, rest are all good.
Old Jan 1, 2013 | 09:01 PM
rexazz2's Avatar
what code remains ?
