A little 4wd trouble shooting needed
Old Jun 19, 2008 | 01:20 AM
stevenf's Avatar
stevenf is an unknown quantity at this point
Default A little 4wd trouble shooting needed
When I first bought my Jimmy, the 4wd worked fine. After I installed the lift and tires, my front wheels wont spin. When I installed the body lift, one of the steps was to remove the vaccum pump under the battery tray from the firewall.(Im assuming this pump is for the engage/disengagement of the front axle.
When I press the 4hi button I get a small motor noise and a slight clunk at the transfercase. When I put it in 4lo, I get an even louder clunk noise. In 4lo, Myengine revs high to make it move(just like its supposed to) but my front wheels dont spin.
Mabey its the pump I removed and put back on? How do you suppose I check this pump? Ive read of putting your finger over the vaccum line to feel a suction......????
Old Jun 19, 2008 | 06:50 AM
Default RE: A little 4wd trouble shooting needed
It isn't a pump. It is a vacuum actuator. Engine vacuum pulls on the diaphragm in the actuator which pulls on the cable to engage the front axle. The actuator requires engine vacuum supplied from the vacuum switch on the transfer case. For this to work, the other end of the actuator (cable end) must be connected to the front axle so that it can pull on the engagement mechanism.
First, verify that everything is connected properly. Then verify that you have vacuum at the actuator when in 4wd & engine running (a vacuum gauge works great here).
*Moving to 2nd Gen Tech* - Please post tech questions in the appropriate tech section. Also, please include your vehicle information in your signature so we do not have to go looking for that information when we attempt to help...
Old Jun 20, 2008 | 02:29 PM
stevenf's Avatar
So the noise and engine rev that I hear in 4lo and 4hi are pretty much guarantees that its just the front axle thats not engageing???? I will check thoughs and let you know.
mb6790
Sep 26, 2011 06:39 PM
noruckus
Feb 19, 2011 06:23 PM
Dark Rider
Mar 3, 2010 10:22 PM
BlazeringSaddles
Nov 29, 2009 07:25 PM
kuraki
Dec 12, 2008 08:09 AM
