long term fuel trims high at idle???
Old Jun 19, 2009 | 07:31 PM
  #21
Definitely. If there is slack in the push rod, that is most definitely taking away from the available lift.
Old Jun 19, 2009 | 08:24 PM
  #22
groundhogman's Avatar
Banned
groundhogman is on a distinguished road
yep thought so and thats what im dredding, i should have replaced the lifters on both sides instead of 1, what do you think caused those lifters to tap like that on both sides on a new reman motor?
Old Jun 20, 2009 | 08:18 AM
  #23
Any number of things. Who knows. The motor may not have been a complete reman... Or maybe wasn't a reman at all...
Old Jun 21, 2009 | 03:02 PM
  #24
Banned
cool well thanks for all the replies!!!!!!when i replace the lifters on the other side and pushrods, i will let you know what i find as far as VACCUM, PERFORMANCE, FUEL ECONOMY AND LONG TERM FUEL TRIMS, AGAIN THANKS!!!!!!!!!!!!!
Old Jun 21, 2009 | 06:39 PM
  #25
Keep us posted!
Old Jun 24, 2009 | 05:50 PM
  #26
Banned
ok i called chevrolet about the balance shaft tensioner kit and they have a list of other parts adding up to about $400.00 do i need a new timing cover or can i just get the tensioner by itself and buy all my gaskets for everything else at advanced auto or something? cause while im already in the engine when i replace the lifters and pushrods i kinda want to take care of this tensioner thing then instead of later if and when it should arise.
Old Jun 24, 2009 | 08:05 PM
  #27
You should be able to just put the tensioner in and get a new gasket for the cover. I do not recall the timing cover being different.
Old Jun 25, 2009 | 05:21 PM
  #28
Banned
cool thanks!! i will let you know what happens when im all finished.
Old Jun 25, 2009 | 05:46 PM
  #29
Banned
BTW what should the vaccum be at idle for this truck??????
Old Jun 25, 2009 | 05:59 PM
  #30
awe341's Avatar
awe341 is on a distinguished road
One other thing that you should check is replacing both of your oxygen sensors. Faulty O2 sensor(s) could be sending incorrect info to your PCM about your exhaust composition and reporting a false lean signal which could account for your fuel trims being so far off.
Just something simple to check before you start tearing the engine apart completely.
