Looking for a blazer.. any specifics to look for?
Old Jan 19, 2010 | 07:32 AM
Mudfrog's Avatar
Mudfrog is on a distinguished road
Default Looking for a blazer.. any specifics to look for?
Going to get a 96-00 blazer for a daily driver. In my area the price range is typically $1500 - 3000 for these years and the mileage will vary from 115,00 to 200,000. Now I'm familiar with K5's but not these.. Is there anything specific that these S10's have issues with especially at this mileage range that I should look for when test driving them?
More specifically 96-00 4 door 4wd.
Old Jan 19, 2010 | 07:45 AM
First off, welcome to the forum! Have a look around. There are quite a few threads on this very subject as well as one rather lengthy "common problem" type thread.
Old Jan 19, 2010 | 08:04 AM
Sisk's Avatar
Plenty of common problems through those years. Keep in mind the front ends changed in 98, and again in 00, so that date range you've provided has 3 different styles.
As Kyle said do some reading around. Most common are 4x4 problems (not working, stuck in 4x4, not engaging etc), annoying rattles, abs/brake issues and a few others. There is TONS of info on this gen blazer.
Old Jan 19, 2010 | 08:07 AM
Mudfrog's Avatar
I will take a look around. I saw tons of threads requesting help but I didn't know which were common issues and which were uncommon issues.. I'll read up a little more.
Old Jan 19, 2010 | 08:17 AM
Sisk's Avatar
This is a good place to start: https://blazerforum.com/forum/general-chat-34/list-common-annoying-s-10-blazer-quirks-5771/
It's an ongoing thread of common and annoying problems with the Blazer. Throughout those years though I'd have to say the most common is 4x4 issues. There are A LOT of problems with the 4x4 system on 2nd gen Blazers. Anything from bad encoder motors to bad TCCM's to vacuum issues etc. etc.
Old Jan 19, 2010 | 04:25 PM
Sirloin's Avatar
Sirloin is on a distinguished road
In general the ZR2's are built tougher, have a wider and taller stance, and are a bit more thirsty. In October of 2009 I found a 1996 clean one owner (base model blazer) 2 door MT 4wd for 1600 dollars. It had 148,000 miles on it but was really clean inside & under the hood. I had to put lower intake manifold gaskets in it, but other than that, it is a great little truck and it gets between 18 and 22 mpg (best mpg is at low highway speeds).
Old Jan 19, 2010 | 04:36 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
what changed in 00??
Old Jan 21, 2010 | 09:14 AM
Mudfrog's Avatar
I hear the intake manifold gasket is a common problem. When I look for a blazer how do I tell if it needs one or not, will it be obvious?
I'll probably focus on the 98-99 year range.
Old Jan 21, 2010 | 10:33 AM
Sirloin's Avatar
Wink Lower Intake Manifold Gaskets
MudFrog,
I was lucky and heard the early warning signs in time to catch the problem before any real damage happened. My intake gasket was leaking coolant into my oil, and at start-up I heard a slight ticking sound. After two or three start-ups I checked the dipstick, noticed an increase in volume on the dipstick and water drops. Then looked into the radiator and yelled "Hello" to hear a faint echo ( coolant was low - oil level was high ). The ticking sound comes from the (heavier) water being pulled through the oil sump before the oil, once they get mixed in the system the ticking goes away. As far as a visual 'tell' ... I like to see an engine compartment that is relatively clean, meaning the previous owners lifted the hood, checked things often and did regular maintenance. Sometimes these intake gaskets leak externally, and the owner thinks it's a cracked block or a freeze plug has popped. Look at the ground where they normally park it. That will give you a lot of ( leak ) information. Take a look at my photo album, I have a few photos about the LIM work I did.
Old Jan 25, 2010 | 11:32 AM
Mudfrog's Avatar
MudFrog,
Thanks for the insight. I will definitely keep this in mind during my search
