loose wire on ignition switch???
Old Nov 17, 2009 | 11:24 PM
bornla's Avatar
bornla is on a distinguished road
Cool loose wire on ignition switch???
It started about 2 months ago (1995 blazer), get in, turn the key to on, get a "click-click (battery is new) jiggle it around (the key) and it starts.
It can go for a day or so, without jerking me around. So now when i get in, I flip a coin on whether it's going to start, the first time or not; or I'm I going to have to seat there and jiggle the key until it starts....any answer on this?...ingnition swich or starter?????....thanks
Old Nov 18, 2009 | 05:53 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
If you can reproduce the same results everytime you jiggle the key, then yes, more than likely it is your switch.
Old Nov 18, 2009 | 06:11 AM
I doubt it is a loose wire. More likely it is a failing contact inside the switch. Check out the ignition switch link in my signature.
Old Nov 18, 2009 | 11:12 AM
bornla's Avatar
Thank you swartlkk; I'm changing out my ignition switch
Old Nov 27, 2009 | 11:07 AM
bornla's Avatar
Well it looks like it wasn't my ignition switch; changed it out, same problem. Starting to think maybe the starter is going bad???? It really doesn't add up, I know (I'm a troubleshooter from way back). Hope someone else has a solution, before I pull the starter!!!!
DJ 4x4
Sep 26, 2011 09:44 PM
dlippiet
21
May 27, 2010 11:22 PM
ussexplorer
Apr 11, 2010 06:53 PM
wwild0471
Sep 25, 2009 01:38 PM
bubba181x1
Mar 12, 2008 02:05 AM
