Lost
The 236 has "extra" speed sensors because it senses differences in speed between the front and rear driveshafts to engage the auto 4WD. I believe the connectors are all the same, right? I would try plugging in the one that was on the old tailshaft to see if it works. I can't imagine you'll hurt anything if you connect the wrong one. The manual case may cause it to set some kind of transfer case code, but I'm not sure.
I have never done this conversion so I don't know the entire process. I take it that your going from an electronic shift 236 to a manual shift 233 transfer case? Is the 233 shift push button/electric or are you doing a conversion to linkage?
I don't know what you have to do to the front (yel/ppl) and rear propshaft (dk gr/lt bl) wiring at the PCM if anything since those sensors appear to go away but the speed sensor wiring to the PCM is ppl/wht = VSS hi and lt gr/blk = VSS low. I believe that your remaining sensor goes to those wires.
Here is a related article that might help:
https://www.journeysoffroad.com/swap...nsfercase.html
If your still stuck, you can PM swatlkk, he has published some threads and probably knows more than me on this subject. Don't say I sent you there just in case it puts him on the spot. LOL.
George
George
I'll try to dig up one of the schematics later tonight after I get the rest of my work done. I just sold my MPCNC so I'm writing up my experience in assembly, operation, etc. for the new owner which has taken up the last few nights. Mix that in with some fire training and some camper upgrades/repairs and it doesn't leave a lot of extra time.
If I posted the 236 speed sensor wiring schematics in the past, I'm sure you could search for that and see verify the VSS wire colors per what George posted as that should be the only one you would be concerned with for speedometer and ABS operation. I sure hope that the rear/front prop shaft speed sensors aren't mixed into the ABS operation somehow on the NV236 equipped trucks.
The only other thing that would need to be verified if simply plugging the sensor into the correct wiring connector doesn't work is that the reluctor ring inside the two cases has the same tooth count and that the sensor has the same response. I'm not sure what technical info is available for these sensors so your next best approach might be to scope the response while spinning the shaft 1 full revolution on each case & count the peaks as well as how high the response is from peak to valley. If they are the same, good. If not... I can't see them being different though.
I've been here a long time!
Simplefish8988
Jul 3, 2011 10:01 AM
nate7493
Sep 3, 2009 04:52 PM
