lost in hesitation
Old Jun 13, 2015 | 04:13 PM
burned's Avatar
burned is on a distinguished road
Gear is probably toast if its 22 degrees out. I recommend a new distributor
GM CHEVY V-6 VORTEC DISTRIBUTOR
Old Jun 13, 2015 | 07:22 PM
Good idea to check the gear while the distributor is removed. You can check timing chain slack without any engine disassembly. Although with the symptoms you have, I doubt that's the problem. Typically when a chain jumps, IF you can get it started, there is extremely low power, but smooth acceleration, and difficult to notice any problems at higher RPM. There would likely be several DTC's in memory too.
Old Jun 22, 2015 | 07:56 AM
DesertStorm's Avatar
thanks for the help. ordered distributor from Skip White last week (thanks Burned for the link) and it fixed it! got the old one out and it was toast. rotor moved up and down at least 1/4" and side to side almost 1/8"
Old Jun 22, 2015 | 08:03 AM
Up and down movement is not an issue. With the way the gears are cut, it pulls the shaft down when the engine is running. There should be no side to side movement though. As long as P1345 is not present, the distributor is meshed correctly, and camshaft retard is "in the ball park", but it needs to be checked and adjusted to zero degrees plus or minus 2 degrees.
Old Jun 22, 2015 | 09:35 AM
yes. i think i am off one tooth with it.. kinda hard to start and the CEL came on right away.. our scan tool at the shop is dead (got left on over the weekend) but i have a backup i am going to use at lunch. i am assuming it is the 1345 code. it runs good, just hesitates when starting now.
Old Jun 22, 2015 | 02:44 PM
ok. pulled codes at lunch.. lo and behold the P1345. pulled data and showed 51* positive CMP retard. restabbed the distributor, and now it runs right at 0. perfect. i am so glad to have the issue fixed.
dougg01
Lifting Tech
19
Jan 21, 2010 02:48 PM
wxj1974
Jan 3, 2007 10:09 PM
NitrousJunkie
Sep 13, 2006 05:13 PM
wxj1974
Nitrous, Super Chargers, & Turbos
Aug 5, 2006 08:44 AM
rx7tturbo
Dec 4, 2004 05:01 AM
