Lost Nut
Old Dec 12, 2011 | 11:03 AM
Blue Jay's Avatar
Blue Jay is on a distinguished road
Default Lost Nut
03, 4.3, 4X4 I was trying to find fuel leak in plenamn, had the plastic dome off and was hooking fuel lines back up so I could re-preassure system and the nut on the left side slipped from my fingers, (working outside cold fingers) and it is not to be found.
I rented a bore scope to look back thru the air passages and still could not find it, took off the lower intake manifold and used scope again to look at top of valves, still not to be found. Only 2 valves (3 & 6)were part open (just enough to see park plug) but not enough to allow nut to pass thru.
Have looked all over engine, frame and ground but still not to be found. Any ideas to try next besides pulling head?
Thanks
Old Dec 12, 2011 | 11:23 AM
You could pull the plugs and take a look in each cylinder. My guess is that it wouldn't make it past the valve and is likely hung up in or near the accessory drive brackets.
midnightmekanik
Oct 8, 2009 08:32 PM
hondacharger
25
Aug 10, 2009 11:24 PM
Annekat91
Sep 23, 2006 01:05 AM
frankjc
Suspension Tech
Sep 10, 2006 04:56 PM
98Blazer
Feb 15, 2006 05:40 PM
