Lost power above 3K RPM
Old May 16, 2008 | 08:25 AM
hilsenteger's Avatar
hilsenteger is an unknown quantity at this point
Default Lost power above 3K RPM
Hi,
Did a 1000km trip yesterday with my 1998 Blazer - had it in cruise at about 110km/hr - climbing a hill, I started slowing down to about 90km/hr - suddenly it started to lurch like it was losing power - I took it out of cruise and it did the same thing driving off the pedal.
Pulled over at the next gas station - a travelling mechanic (??) that I ran into said he thought it was probably the fuel filter and suggested adding some gas line anti-freeze to clear out gunk in the filter.
There's no problem starting, idling, and driving up to about 100 km/hr, as long as you're on the straight and narrow -- anything where you have to step on it kills the power and it starts lurching.
I was thinking about changing the fuel filterfirst and then going from there. Any other suggestions as to what this could be? The other suggestion from the guy at the gas station was the fuel pump, but my experience is that pumps usually just go, they don't drive for another 400km.
Being on the road, I'm trying to remember how to depressurize the fuel system first - can someone remind me what I do to depressurize - otherwise, I could just deal with some loss of fuel (at $1M per gallon - ha ha).
Any tips would be appreciated.
Thanks.
Grant
Old May 16, 2008 | 08:45 AM
rriddle3's Avatar
Default RE: Lost power above 3K RPM
I would also check to be sure the catalytic converter is not plugged up.
Old May 16, 2008 | 09:29 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
easiest way to depressurize is to pull the fuel pump relay and then try to start it. Or if you let it sit for a day or two it will just get you fuel coated not sprayed.
Old May 16, 2008 | 05:49 PM
kross's Avatar
kross is an unknown quantity at this point
Mine did that, too. It was a plugged cat. I've read on here you can check if that's the case by pulling out (and disconnect the wire) an O2 sensor before the cat.
Old May 27, 2008 | 12:45 PM
Just wanted to follow up - replaced the fuel filter and noticed an immediate improvement in power - drove another 1000km home and had no problems.
Thanks for the quick replies and suggestions!!
peters702
Jan 29, 2010 10:50 AM
jshultz78
Dec 24, 2009 03:13 PM
dustinsroberts
Oct 15, 2009 12:08 AM
aypapi
May 24, 2007 12:47 AM
zashwood
Headers, Intake, & Exhaust
Sep 7, 2006 08:51 AM
