Lots of trans related issues
i just recently got a 97 s10 blazer lt...previous owner put in a transmission, and noticed it was leaking pretty bad so he sold it to me...i noticed right away the leak is coming from in between the transmission and transfer case....upon driving home i hear this loud clunking/banging on the floor. after getting it home i look and i can see the front u koint closest to the transfer case is actually making contact with the floor....but the real kicker is i can moved the transmission and transfer case about an inch up or down if i grab the tail shaft housing...im thinkign this is just enough play to cause the u joint to slam into the floor? and is it literally just that 1 ruybber trans mount holding the entire assembly up? im just kinda worried and hoping i did nt get a lemon, but if i could figure out why i can move the tansmission up and down and the leak between the transfer case and transmission i think i will have a good running truck...please help guys. i appreciate it in advance
Sounds like one or more are shot. If a motor mount goes bad, it can take out the trans mount as well.
The transmission mount is easy enough to remove and check. The motor mounts are quite a bit more challenging.
well i can kinda see the trans mount squish upon moving the trans and xfer case by hand....ok so i have to do some mounts...how hard is it to pull the transfer case to see what is up with the leaking in there? i kinda see a adapter between the trans and xfer case..do i pull it literally off the trans or after this adapeter piece thats about 4 inches long?? thanks again
You would pull it loose where it connects to the transmission. Use RTV to seal this interface back up. Just be sure to clean things really well before applying a thin layer of RTV.
While you have the transfer case down, it would be a good time to replace the sometimes problematic front input seal.
got the transfer case out....the seal has a little tear in the front input of the transfer case...also on the bottom of the trans by the out put shaft of the trans there is a hole in the bottom inside case....is this normal? becuae when i took the transfercase adaptoer off i found this hole leaking alot of trans fluid...i think its factory...but dont know
zlathim
02-13-2018 04:22 PM
1LoudJimmy
06-26-2013 07:24 AM
racsan
12-01-2011 05:48 PM
93 s10 justin
03-05-2010 04:09 PM
