Low power/no acceleration after warmed up
Old Oct 12, 2014 | 03:38 AM
  #61
Williamsb7181's Avatar
Williamsb7181 is on a distinguished road
Had a very similar problem with my 98. Try driving with maf sensor unplugged. If it runs like normal thats your problem.
Old May 18, 2015 | 11:03 AM
  #62
tondox1's Avatar
tondox1 is on a distinguished road
Fixed it!!!
No More Huge Fan noise under hood and no more power loss when engine is warmed up!!!
I after spending thousands of dollars on various sensors and repairs, fuel injectors, fuel pumps, etc. I went with this AC Delco Fan Clutch ACD# 15-4684, GM# 15154901
This part cost me about $90 and shipping.
The fan clutch was one of the items I replaced from the get-go, but used a different part/manufacturer and it cost about $40-$60 at the time. And my issue was still present
Once I installed the new Fan Clutch from AC Delco, the huge fan noise was present for about 5 sec, then dissipated. I ended up driving from Arizona to Denver the very next day (about 900 miles). Not ONCE did the fan/power loss issue surface......
My Truck stayed under 190 Degree entire way through!
Attached Thumbnails Low power/no acceleration after warmed up-img_7380.jpg
Old May 19, 2015 | 02:06 PM
  #63
jimspahr@msn.com's Avatar
Congrads! I can see how the new fan reduced the roaring noise, but how did the fan help the low power/no acceleratin part of it?
Old May 20, 2015 | 06:45 PM
  #64
tondox1's Avatar
I believe the first time I replaced the fan clutch, it was either a bad one, or just functioned/engaged once the engine temp hit around 130-140 degrees. After knocking around the idea that the problem only occurred once the Fan clutch would engage at such an early temperature, I tried to think "How do we keep the Fan Clutch area COOLER?" The only conclusion I had left was to try a different fan clutch...
Old May 21, 2015 | 07:57 AM
  #65
I know many are finding out that buying OEM aka AC Delco or Delphi up front is cheaper in the long run. It is hard to do when you are on a tight budget and you are presented with 'bargains' on the net /ebay. But I like doing the job once and not chasing around after an illusive trouble. Exp. when you thought you had fixed a problem with inexensive parts. Thanks for posting your search for the solution.
tondox1
May 30, 2019 01:44 PM
camocarrier
Sep 4, 2011 10:17 AM
Brock Samson
Jul 24, 2011 08:57 AM
epederson
Dec 7, 2010 06:34 AM
summer
May 3, 2010 08:10 AM
