Lower intake gasket time
Old May 14, 2017 | 03:02 PM
  #21
pclausen's Avatar
pclausen is on a distinguished road
I did a little Googling and out the different between the old style spider and the new one. So I went ahead and ordered this guy:
SPIDER VORTEC FUEL INJECTOR 6 CYLINDER 4.3 L 1995-2002 GMC/CHEVY TRUCKS (FJ503) | eBay
Old May 20, 2017 | 11:12 PM
  #22
No false Bravada's Avatar
No false Bravada is on a distinguished road
What's this little piece on the bottom of the FPR? Does it go anywhere?
Old May 21, 2017 | 09:49 PM
  #23
Nvm. Broke a couple of the connections on the distributor cap and had a no start. Getting a new cap in the morning.
Old May 22, 2017 | 05:24 PM
  #24
Need help ASAP. New cap and rotor, set in time, backfires through intake and won't start. Got spark and fuel, all connectors seated properly.
Old May 22, 2017 | 05:57 PM
  #25
FMB42's Avatar
FMB42 is on a distinguished road
First, triple check that you have the spark plug wires right (crossing #3 with #5 is pretty easy to do with these engines.
Next, double check that the cap is on correctly and that it's tight (but not too tight). Your Blazer has a plastic distributor body (unless it's been upgraded). These plastic dists are notorious for both breaking at the cap hold-down lugs and for wearing out prematurely. Breakage at the cap hold-down lugs can, of course, result in timing errors and backfiring ect. Otherwise, the dist isn't timed just right which, if true, will require an 'engine disturbed' distributor install (#1 cyl at TDC on the compression stroke). There's a sticky on this forum about this (and a bunch more across the Net). Meanwhile, please DO NOT attempt to start again it as it is now. Make triple sure that everything is right before you try to start it again.
Old May 23, 2017 | 04:33 PM
  #26
After many hours of blood, sweat, tears and swearing, the Bravada is back together and running. No codes, no dummy lights, she's good to go.
Old Jun 24, 2017 | 11:25 AM
  #27
Bagherra's Avatar
Bagherra is on a distinguished road
Does the distributor have to come out to do this job?
Old Jun 24, 2017 | 02:15 PM
  #28
Yes. I would say it isn't recommended to try alone.
Old Jun 26, 2017 | 10:34 AM
  #29
Bagherra's Avatar
Old Jun 27, 2017 | 05:13 AM
  #30
The job as a whole isn't something I'd do alone. Especially when it comes to setting the timing.
