lower intake manifold question
so i took off my lower intake manifold today to replace the gasket (98 4x4). my question is what can i check/test now that i have it off? anything with the pushrods, spider injector, or anything like that? any words of warning or suggestions? also what are the torque specs of the lower intake bolts?
thanks in advance
-Mike
thanks in advance
-Mike
From D-tips DIY guide
![](http://www.justanswer.com/uploads/ebrock63/2008-07-15_203234_7.png)
Just went through this. Ended up having a P0300 due to a clogged poppet valve on cylinders 2 and 5. I think the lower intake manifold just got moved/turned around too much and some brake-clean may have gotten in them. I would disturb it as little as possible. An extra set of hands to keep the wiring harness and everything else out of the way is priceless because you have to put the manifold back down as straight as possible without sliding it.
Make sure you wait the recommended dry time for the RTV before firing it back up.
And the usual, change the oil/filter right after and again in about 500 miles.
How bad were your gaskets? Did you get the updated metal framed gaskets to put back in?
When re-installing the manifold, ensure that the fuel lines enter the connection at the back of the engine. Place the intake straight down on the engine. If at first the bolt holes do not line up, pick the intake up and reposition it. DO NOT slide it as this will push the silicone away from the block. Start all eight of the intake bolts in the heads, then gently snug them all down uniformly. Start the torque procedure with about 89 inch lbs., starting in the center and moving outwards in a circle. Next, torque to about 106 inch lbs. in the same pattern. Finally, torque all bolts to 11 ft lbs. Do this final step several times to ensure that all bolts are evenly tightened.
thanks for the reply.
the gasket wasnt too too bad but bad enough to cause an annoying leak and i didn't want it leaking into my oil so i figured id do it now rather than later
and yes i have the updated felpro gaskets that come in a kit. also new intake bolts.
EDIT: ill try and get some pics of everything before and after
also im talking to a friend of mine that used to be a GM technician and i was told i might need to do a relearn for the distributor since its more of a glorified cam sensor?
Use thread sealer on the intake bolts. With such low torque on the bolts, the sealer keeps them from loosening up. No "relearn" is necessary for the distributor. What he is referring to is checking and adjusting camshaft retard with a capable scan tool. It involves adjusting/rotating the distributor to calibrate the camshaft position sensor which is inside the distributor. The odds of dropping the distributor in and getting it perfect are not good.
I was told nothing on the bolts because it messes with torque readings. If you marked the distributor and rotor location, it technically should drop right back in. However it seems this is often not the case, or at least it wasn't in my case. Had to line up timing marks and have cylinder 1 at TDC to get everything back in even though nothing changed while we had it apart. No relearn is necessary but it is easy to be 1 tooth off. If you get a code for cam/crank sensor not communicating properly (I forget the exact code), you are most likely one tooth off. Also, remember the rotor doesn't fire where the plug wire plugs in. It fires for that cylinder on the opposite side of the cap.
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
I stand corrected on both accounts.
okay i got the intake back on and torqued down following the 3 step torque sequence. my only issue now i getting the distributor to line up even close to where it was marked. did i miss something or so i just keep playing with it until itll drop in?
What often happens is if you do not get it exactly right the first time, the oil pump drive that engages on the end of the distributor shaft below the gear can turn, prohibiting you from dropping the distributor into place in the correct position. A long screw driver, mechanics mirror, a flashlight, and lots of patience can get it back into proper alignment.
yea i ended up getting it to line up properly. thanks all for the help! ill be posting some pics shortly
