maintnence check up
Old Feb 16, 2009 | 03:04 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
Default maintnence check up
ok so ill be coming up on 55,000mi and are there any areas i should paysome extra attention to?? i had the tranny flushed about a week ago ill be changing out the plugs, wires, and cap and rotor this week, and once the weather gets decent new brakes all around. it also seems a bit sluggish nothin major but im hoping the the plugs, wires and cap along with recharging the filter takes care of that.
Old Feb 16, 2009 | 06:53 AM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default RE: maintnence check up
Add some Seafoam to your next tank of fuel to clean your injectors.
While you're doing your brakes inspect your balljoints, tie rod ends and idler arm for wear.
Old Feb 16, 2009 | 09:52 AM
rriddle3's Avatar
How long since you did a coolant drain and flush?
Old Feb 17, 2009 | 02:36 AM
mikeinwi's Avatar
its never had a coolant flush as far as i know, but i did take the radiator cap off about 2 oil changes ago to take a look and it was nice and clear and wasnt cloudy or gunked up or anything.
Old Feb 17, 2009 | 06:41 AM
rriddle3's Avatar
Then I would add that to the list of things to do.
01xtreme
Feb 5, 2020 01:03 PM
Jovian2k
Jun 15, 2005 11:24 PM
Jovian2k
Apr 11, 2005 05:12 PM
45auto
Feb 24, 2005 09:30 PM
blazerguy64
Feb 8, 2005 05:42 AM
