major motor oil leak
Old Sep 15, 2010 | 09:52 PM
totalljen's Avatar
totalljen is on a distinguished road
Default major motor oil leak
we have a major leak... about a quart of oil on the driveway.. hubby crawled under and cleaned it up looked around and sees where its coming from but does'nt know why.. anyone have pics of the underside of there 2000 or same model blazer for him to look at? thanks a bunch
Old Sep 15, 2010 | 10:12 PM
old skool luvr's Avatar
welcome to the show.
ummmm...................that question would be better suited in the tech section, not the New Member section.
if you already know where it's leaking from, why not just tell us? someone might have run into that same issue before.
but again, that's a question better suited in the proper section.
Old Sep 16, 2010 | 02:00 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
Old Sep 16, 2010 | 02:23 AM
R2P's Avatar
R2P
R2P is on a distinguished road
Knowing where the leak is would help a lot. Could be a cracked oil pan, bad gasket, damaged/loose drain plug, etc.
Old Sep 16, 2010 | 09:20 AM
totalljen's Avatar
sorry guys still trying to figure out how to navigate the website.. i would be happy to post in a different section if someone would tell me how lol..
Old Sep 16, 2010 | 11:29 AM
nj4x4blaze's Avatar
Your thread was already redirected to the correct location.
Old Sep 17, 2010 | 12:08 AM
soooooooooooo.....................................
where is the leak coming from?
Old Sep 17, 2010 | 05:46 AM
nj4x4blaze's Avatar
From the motor.. Duh!!!!
Old Sep 17, 2010 | 08:35 AM
totalljen's Avatar
hahaha ok so i took a better look being that i am not really a mechanic though a mechanics daughter .. it is coming from the front of the motor.. my husband thinks its coming from the oil pan... in hi sopinion it looks like the oil pan is actually sitting on the front end EEK! which i hope is not correct.. however my daddy is going to come over this weekend and hopefully we will solve the problem without too much expense.. no cherry picker here.. wish me luck
Old Sep 17, 2010 | 10:41 AM
LannyL81's Avatar
If your 2000 is like my 2002; I had one front pan bolt loose and the other one missing. Seems to be a common problem. If all the pan bolts have fallen out, you are going to need 5/16" x 18 - 1.25" bolts.
Good luck. Could you send your "daddy" my way to fix the vibration problem my Blazer is having?
