Manual HVAC Air Distribution Control
Old Jan 5, 2022 | 09:40 AM
LannyL81's Avatar
Default Manual HVAC Air Distribution Control
Hey!...has anyone found a replacement for the manual HVAC A/C/heat/vent distribution control without replacing the entire panel? Or is there a rebuild kit out there somewhere for it? Have looked at RockAuto, nothing there....ebay has used ones which I do not want since I already have one of those.
Thanks
Old Jan 6, 2022 | 11:27 PM
Are you referring to the control panel for the HVAC system? I think Dorman might be selling them. You could also try a wrecking yard.
Old Jan 6, 2022 | 11:28 PM
Dorman? Wrecking yard?
Old Jan 10, 2022 | 02:21 PM
LannyL81's Avatar
Hi Christine, yeah the air distribution control in the HVAC panel. I think I saw that Dorman has the entire panel and that may be my only path. Do not want a used one as the air distro control might be worse than the one I have.
Would be really nice if I could just find a replacement air distribution control instead of the whole panel.......or a rebuild kit for it. Probably just one O ring in there....I have not taken it apart to look at...which I likely will not do until weather warms-up and I no longer need heat. If I do find that it is a simple O ring that is leaking, then I might be able to find a replacement. If I do, I will share the info.
Old Jan 15, 2022 | 09:27 AM
LannyL81's Avatar
Hey was searching ebay the other day and found a new replacement air distribution control for the previous generation of Blazers. Sure looks like it is the same, but will need to do more research into part numbers.
austrochevy
15
Nov 11, 2024 02:31 PM
OhioLefty
Dec 4, 2012 01:31 AM
jonesbastoria
Aug 26, 2012 10:08 PM
gojorg
Nov 18, 2011 08:55 AM
Leearchibald
Dec 8, 2010 11:51 AM
